Zum Hauptinhalt wechseln
Alles was du brauchst, um dein iPhone zu reparieren! Von den neuesten iPhone 15-Modellen bis zum allerersten iPhone überhaupt - bei iFixit gibt es kostenlose Anleitungen zum Reparieren und Zerlegen für jedes iPhone und dazu auch die besten Ersatzteile, Werkzeuge und Tipps in der Galaxis.
36476 Fragen Alle anzeigen
Screen is flashing Colors-nothing visible. Why?
My iPhone 3G 16gb is flashing colors on the screen with scanlines (like from a tv). It got a little wet when I was in the rain, but not soaked. Do you know what I need to replace? There aren't cracks in the screen.
However, it does power on an off. I just can't see the screen.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare
I don't know if this could come from a connection problem. i have an iPod touch with the same problem. it looks like a test pattern that always runs as soon i switch the device on. the iPod had a water damage and i was able to get some live out of it. in case of my iPod - it gets pretty warm while displaying the pattern (but it could be normal since the graphics chip works pretty hard while displaying this stuff until the i switch it off. restoring didn't changed anything. but as i said - it looks like a programmed test pattern
von
I measured the temperature on my iPod touch - it goes up to 190°F. thats way too much - but still - it looks like programmed. the iPod could not be resetted and is not recognized by itunes. i think i try to find more infos why something like this could happend in the first place (don't care about the iPod, got 2 defective for around 15€)
von
Thanks everyone. I tried to replace things and it didn't work out so well. Now I have no display at all and my cheap adhesive didn't stick well so I have to wait for more in the mail. I suspect things arent connecting properly with the LCD. However, the phone part works. I plugged it into my computer and it recognized the phone in iTunes. Also, if I hold down the button and power button it takes pics like a working iPhone does.
That's good to know it's not water damaged. I'm going to order a completely new LCD and more glass and digitizer to see if that does the trick.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Take a look at you #1 connector (the one to the LCD)clean it a bit with some IPA and inspect for damage. Those tiny little pins are what transmit visual data to the screen. The fact that it is flashing might be a good thing, could just be residual build up from getting wet. A blown pin shows up blank white with lines. Good luck.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for the reply. Which guide on here will show me how to do that when I disassemble the phone? Also, what is IPA? I'm sorry im a noob. I appreciate the help.
von
Here's the guide your looking for (Removing the screen assembly/connectors)
Bewertung 0
3 Kommentare:
thanks everyone! What's this IPA stuff to clean it though?
von
isopropyl alcohol, take a good one with more than 90%
von
also make sure that you let it all dry before reassembly.
von
the same thing is happening to my phone. a few drops of water got on it but not much. i can't see anything but when i called it it still works. i unlocked it without looking at the screen. all that still works except the screen.
Bewertung 0
Antwort hinzufügen
jlc wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 10,939
