Xbox Powers on and immediately powers off
Has anyone figured out exactly what is causing the problem with Xbox Ones that power on, and immediately power off. The power brick is lit orange which instantaneously turns white once the Xbox is turned on directly from the console, but immediately powers off.
This is a very common problem that Microsoft will not discuss.
Ist dies eine gute Frage?
61 Kommentare
Have this same issue, powers on for a few seconds then turns off
tried replacing power supply (x2 times) tried replacing power cord (x3 times)
Tried Factory reseting
Tried offline update
Tried repairing partions on HDD
Tried removing fan and cleaning and also cleaning and reapplying thermo paste
Tried cleaning motherboard with alcohol (91% and 100%)
Tried power cycling
Tried new HDD and SDD
and yet I have NOT had any luck. I didn’t want to give up on her, but it looks like that’s the only option at this point!
If you guys have any other suggestions I’m all ears ........
von moisesq
Get a hair dryer, put it on hottest setting, put it on high, blow out the vents... Didn't believe people that said it worked until I tried it. It worked for me. Thinking maybe was just a dust buildup?
von Ashley Latimore
I am Convinced there is some sort of Temperature Switch that Microsoft put in there that if you spill a little liquid or drink or anything into the Xbox One then it triggers this problem... The Xbox One will Power on for a SECOND then Immediately cut off.. To Fix the problem.. You take a Hair Dryer and blow HOT AIR into the Xbox One's Vents.. This Instantly FIXES the Problem Somehow... I worked for me.. I could Not Believe it but my Xbox One Now Powers on Perfectly, Just like before.. This is some BS that Microsoft Engendered into the Xbox One to make us have to send it in for Service and pay more $$$$ No Lie.. Has to be... Just my 2 cents.. if it's That easy to fix.. Something is UP with this.. How can Hot Air Fix it? But It Does... ;)
von Mountain View777
Take it apart no joke mine was doing this and I took all of the main screws out and it works completely without them but if I put one screw back in it will $@$* off and stop working
von dakota knutter
Had the same exact issue. Powered Xbox on, stayed on for a few seconds and powered off. Power brick went white to orange. Opened it up, blew it out, got a heat gun and heated the area fan/heat sync for about 4-5 minutes. Flipped it over and tightened the 4 heat sync screws at the bottom of the system. Powered it up and problem solved. I did blow out the power brick fan as well. Easy Fix!
von Frank Stanley
56 weitere Kommentare anzeigen
