Wacky Macey has issues
This bugger has more problems than me and my last girlfriend said I had a lot.
First off it would boot up but only with an external monitor. Zilch on the laptop screen even with light shining behind the screen.
After replacing the display it would boot up but didn't have any backlight on the new display, could now see items on screen though.
I found the backlight fuse to be bad so I replaced it.
Now when I connect the power supply (battery @ 90% charged and connected) the unit starts on its own however the sleep light gives one quick blink, fan kicks on and then it shuts off and repeats the process.
Never chimes (did before), display doesn't come on at all in fact the only thing that happens is the single flash and quick cycle of the fan.
Oh, the first couple of times the charge light was dim. It is now normal green and switches to amber.
Any ideas?
Ist dies eine gute Frage?
2 Kommentare
Can you give us some background here. What happened to your system? Did you get it wet, drop or bang it? Does the case have any dents? if it got wet where and what. Are you using an Apple power adapter or someone else's?
von Dan
Cable for the display became chaffed, open wire cut the signal to the display and another shorted back light fuse. Replaced it with a fully functional and complete display/lid.
Unit is undamaged in any way other than the former display cable.
Everything is OEM except for the new fuse which is a direct replacement. Have done about a dozen of them so far.
Unit had lost it display some time ago so I was using it with and external monitor. Finally decided to fix my own stuff for a change.
Didn't have a single problem with it as far as operating till now.
von Dana
