Zum Hauptinhalt wechseln
2, 2.26, 2.53 oder 2,66 GHz Core 2 Duo-Prozessor
106 Fragen Alle anzeigen
Frage geschlossen
Where to find a replacement optical drive
Looks like my drive is broken. I'm looking to replace it. The closest replacement I have found is this drive from SilverStone http://www.amazon.com/SilverStone-SOD01-... and this http://www.madeinchina.com/2722501/S3532...
Is there a better source than these? OWC doesn't seem to have any SATA versions of the optical drive.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
That looks like it's true at the moment, however stock changes so check back some other time and they might have it. However you probably want to get this part soon, so check here, that's probably the second most reliable Mac e-store there is. You'll find links there also on how to install it and videos to guide you, however right here is iFixit's step-by-step installation guide].
War diese Antwort hilfreich?
Bewertung 0
How about the part from
here? (parts button on the right).
If this answer is acceptable please return and mark it.
Good Luck,
N.
Bewertung 0
1 Kommentar:
You should double check that link machead
von
Unless I missed it they don't have an optical drive. Just the hd enclosure for the optical drive bay which I already ordered by mistake. I would love it I'd iFixit had the optical drive. Then I could use my credit from te enclosure return.
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 2,447
