Zum Hauptinhalt wechseln
This page contains replacement guides and a troubleshooting section for the Craftsman Scroller Saw Double Insulated 5/8" Stroke-Variable Speed (Model 315.10721). This handsaw was manufactured in 1979 by Sears, Roebuck and Co.
7 Fragen Alle anzeigen
Why is the saw overheating?
The saw tends to overheat frequently and the motor makes a weird humming sound. What can be done to prevent the overheating?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Depending on the age, rebuilding/replacing the bearings or arbor... getting a different saw.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 1
Check the electrical cord. make sure there are no broken strands at either in where it attaches to the drill or at the outlet. Make sure you are plugging it into an outlet that is not loose.
Bewertung 0
Antwort hinzufügen
Riley Hilliker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 419
