Zum Hauptinhalt wechseln
This page contains replacement guides and a troubleshooting section for the Craftsman Scroller Saw Double Insulated 5/8" Stroke-Variable Speed (Model 315.10721). This handsaw was manufactured in 1979 by Sears, Roebuck and Co.
Why is the saw blade bouncing when I am making a cut?
When making a cut the saw blade seems to bounce up and down. It will not make a clean cut through the material. I have tried using different speeds but it is still bouncing
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Wrong blade for material - too big, too large, too dull.
What material are you cutting. How thick is the material, what type of blade are you using, how many teeth per inch. The answer to all those questions contains the solution to your problem.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Riley Hilliker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 119
