Zum Hauptinhalt wechseln
AC-Netzadapter für MacBook, MacBookPro und MacBook Air. Ausgestattet mit einem magnetischen Stecker, der sich von selbst trennt, wenn daran gezogen wird. Die MagSafe Netzteile der ersten Generation (2006-2012) haben einen etwas dickeren L-förmigen Stecker. Erhältlich in 45 W, 60 W und 85 W.
65 Fragen Alle anzeigen
Change Magsafe adapter to Magsafe2
I have and older Magsafe Adapter from 2009 MacBook pro. It was broken with the general cable issue. I have fixed it, however it's unused now. I can buy Magsafe 2 repair cable to use with my newer macbook but I don't know whether the voltage will fit. I don't want to burn my mac.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
U.S. shipping only companies are not a solution.
I've read on wiki that the voltage (not wattage!) are different. I would like to see whats inside of the original magsafe to magsafe 2 adapter. I don't need the adapter. I was asking whether I can solder the magsafe 2 adapter to older magsafe AC.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your Mac will only pull as much power as it needs. The voltages are the same. The difference is in the wattage. Here's an adapter you may need: http://store.apple.com/us/product/MD504Z...
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
The inner large pins are V+ (14.5 / 16.5 / 18.5 VDC). Measuring with no load will give 6.86 V DC for MagSafe and about 3 V DC for MagSafe 2; the full voltage is provided after a ~40kOhm load is applied for one second.[8]
von
Hello,
Based on the above answer , it is possible to use a magsafe 60w charger from a1181 macbook 2008 to a newer macbook air 2014 with magsafe 2 , with just this converter (MagSafe to MagSafe 2 Converter - Education - Apple) . Is my guess right?
von
Savvas. It will work just fine.
von
Antwort hinzufügen
masterjet wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 856
