Zum Hauptinhalt wechseln
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Fragen Alle anzeigen
Blank screen and odd behavior of MacBook and iMac
Hi there,
when I connect my display, it is recognized by iMac (2012) and Macbook Air, it shows up as LED Cinema Display, speakers, mic, iSight camera, USB ports are working and I can move the mouse cursor where the display should be.
But the screen is black. No dim light, no faint image under a flash light, it is pure black. Additionally the iMac seems to have micro freezes or at least the mouse moves very slow and stutters when I connect the display. The MacBook Air's internal display shows artifacts and it also seems to freeze and the mouse doesn't react well. As soon as I unplug the display, everything goes back to normal.
Can only the LCD be the faulty part here? How can I find out what needs to be replaced? I've read about voltage checks on power supply and logic board and test points, but where do I find a 'map' of these boards to identify these test points?
lg, Alexander
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Could be the this problem.
Can you get Apple to diagnose/estimate what's wrong? These are very complicated units.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
elvock wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 415
