Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
794 Fragen Alle anzeigen
Replacement screw for MacBook Pro trackpad clicker adjustment screw
While trying to adjust the tri wing screw for the clicker of my MacBook Pro Mid 2010, I striped the screw. I could possibles drill out the screw but can't find a replacement screw for it.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I also have the same problem. I need to find a replacement screw tri wing size.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Some auto or hardware stores have a compound for stripped screws. You're not holding elephants you just want the screw to stay where you set it. (I'm assuming you can turn the screw to the proper height).
Gasket compound or superglue may also do the trick.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Anky wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 457
