Zum Hauptinhalt wechseln
Reparaturanleitungen und Hilfestellungen für alle Arten von Batterien und Akkus.
74 Fragen Alle anzeigen
Risks of short-circuiting Li-ion battery?
I received a new Haier Li-ion battery (haier h11255) for my cell phone and although it seems identical to the old one, it does not work. After some tinkering I discovered that the 4 'pins' on the battery are in another order then they should be. I can easily fix this by connecting two of the pins, which I tried using a paperclip. Is there any risk doing this? If so, what are they?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Definitely get rid of that battery. One of the four pins is used to measure BTemp (battery temp.). When it's temp. is beyond a specified range, the battery will stop charging to prevent overheating. Unordered pins are a bad sign.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Return the battery and get the correct one. Don't chance it!
The battery can explode or catch on fire if sorted.
Bewertung 1
Antwort hinzufügen
Tom wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 521
