Screen has several wide and narrow lines running through it
Several light to dark lines running through the screen after start up. Faded color between them. Tried pulling the battery/rebooting but no luck. Any ideas?
Ist dies eine gute Frage?
Menü
Deine Einstellungen
Hier handelt es sich um ein großes Smartphone von LG, welches im Herbst 2014 veröffentlicht wurde. Das LG verfügt über ein Quad HD IPS-Display und eine 13-Megapixel-Kamera.
B Noyes, not seeing what you see and just from your description, it does sound like a bad LCD. You do want to make sure that your cables are properly seated etc., but ultimately it sounds like a bad LCD to me. Hope this helps, good luck.
There's a connection issue with the tiny pins that connect your LCD to your motherboard.
From experience, try to determine if you need a new motheboard or LCD if you can before you start buying replacement parts.
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 2,829
