Replacement screen wont light up when mid frame is fitted
I recently replaced a cracked screen in a friends Galaxy S4. When I first put the phone back together I thought the new screen was faulty as the phone would turn on but the display wouldn't light up. After some fiddling around I tried turning on the phone while I had the mid frame removed and to my surprise the screen worked just fine. Upon re-installing the mid frame the screen stopped working again. I removed the mid frame once more, turned the phone on and then began to snap the display assembly back into the mid frame. Everything was fine until I snapped the display assembly and the mid frame together around the top left corner near the volume button at which point the screen cut out. Does anybody know of a way that the screen could be shorting out? Or could it perhaps be pressure on the digitizer flex cable? Any assistance would be greatly appreciated.
Ist dies eine gute Frage?
Hi, did you ever find a solution to this as I have exactly the same problem.
Kind Regards,
Danny.
von Danny
