Zum Hauptinhalt wechseln
The Canon PowerShot is a 5.0 megapixel camera with 4x opitical zoom.
14 Fragen Alle anzeigen
Broken ZIF Retaining Clip on CCD Connector
I'm trying to replace the CCD and broke the retaining clip on the ZIF connector.
It's a 28-pin connector with approximately 0.381mm pitch.
Does anyone know a part number or manufacture so I can order a new one and swap retaining clips?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I fear you've got quite a challenge there. If you can find a supplier you may find the website is in Japanese or Chinese with a minimum order of 1,000! Your best bet is probably to put a watch on eBay and you may be able to get another A610 cheaply perhaps with a different fault from which you can cannibalise the apropriate part, or the whole logic board so as not to risk damaging the clip in trying to transfer it.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Bob Peters wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 173
