Zum Hauptinhalt wechseln
Das Samsung Galaxy S3 ist ein Smartphone mit Multitouch- und Drahtlosladefunktion, ist Eyetracking-fähig und hat einen vergrößerten Speicher.
459 Fragen Alle anzeigen
display brightness not increasing or decreasing
I have a samsung galaxy s3 i9300. Its screen got cracked so gave it to a local repairer.he replaced the whole display and touch.the touch is working fine but now the display brightness is neither increasing nor decreasing. So my question is.is there any problem in display?
Ist dies eine gute Frage?
Bewertung 12
1 Kommentar
sir mera samsung j5 ki brightness work nehi kar rahi ha ji kya karu ma plz.. mare problem ko solve karo ji
von
Einen Kommentar hinzufügen
10 Antworten
Hilfreichste Antwort
The replacement screen u got is an lcd whereas the original one is an led.thats why the brightness cannot be controlled
War diese Antwort hilfreich?
Bewertung 7
2 Kommentare:
but there aren't a solutions for brightness check with an led display?
von
I would have believed this until I used a 3rd party app to check control brightness, that worked perfectly fine. I would try a phone reset but right now using the app.
von
Hi Nitish,
Are you sure auto-brightness is not activated?
Perhaps energy saving is enabled?
To test everything with your screen i suggest you launch the test menu and see if everything works there, there is a special button called "dimming" there to test as such;
-> go to your "keypad" (as if you want to call somebody)
-> Type in: *#0*#
It should start the test menu instantly.
Let us know what the tests do :)
Bewertung 3
1 Kommentar:
In dimming test it showing three colours. Red,blue and green. Nothing else is happening
von
go to play stor install apk name NIGHT MODE it can be easly fixed
ukrain rx
Bewertung 2
If you have replaced your display folder then sometimes you face this problem , because of cheap quality display folder .
For this you have to download night mode application from play store .It will work for you.
Bewertung 2
Reset your device and off the auto power saving and try again
I think its work unless there is a hardware problem
Bewertung 0
If you have changed your phone display then it might create problem because some china display doesn't have the hardware that support display brightness. If not so then try factory data reset this might work.
Bewertung 0
Yes bro u are right? This happens to me also,it is only because shop owner replace not the original folder infact any third class , cheaper folder?
Bewertung 0
My mobile brightness not increase problem samsung j7
Bewertung 0
First check the auto brightness option,This is the symbol of copy Lcd only to display the graphic not controlled light system and phone also goes to heating up problem better to change original OLED LCD.
Bewertung 0
brightness not working samung c7000
Update (09/17/2019)
Bewertung 0
Antwort hinzufügen
nitish tokas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 43,034
