Zum Hauptinhalt wechseln
Das Samsung Galaxy S4, Modell i9505, ist mit einer 13 Megapixel Rückkamera und einem 5 Zoll 1080p Display ausgestattet.
526 Fragen Alle anzeigen
S4 I9505 intermittently cant read or use SIM card.
My s4 normally reads my SIM card no problems, until about a month ago, when it started intermittently losing access to the SIM card, blocking it from the network and preventing calls. Sometimes a reboot would make it work again for a bit. I tried a few other SIM cards with the same results.
The strange thing is I find if I remove the phones back plastic chassis exposing the main board the phone reads my SIM card no problem, and will work continuously until I put the back chassis back on.
I also found if I carefully put the back chassis back on the phone, but leave one side not fully clicked in place, the phone still reads the SIM card OK, until I click the last few bits in place.
I bought a replacement back chassis and found that the phone works properly with it fitted, using other SIM cards. But once I put my own SIM card in it wont read it properly again. My SIM card works fine in other phones.
Any help or info much appreciated.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Very odd. I just had this same thing happen on my iPhone 5. What carrier do you use? I use a Verizon reseller and a month or so ago, it started giving me pop-ups every couple hours that said "No SIM" or "Invalid SIM" and wouldn't let me access texting, calling, or data (Wifi still worked) and would stay like that until I restarted.
I contacted the Verizon reseller and they said I needed to buy a new SIM (just got this one in the last 6 months). I didn't want to pay for that so I just waited and it hasn't done it again in at least a month.
How long has this been going on? Have you checked if the chassis pushes on the SIM or board? I don't know much about Samsungs so pardon my question, can your phone tell if the cover is on or not? If not then it has to be a physical problem since taking the cover off helps.
You could also try contacting Samsung, your carrier, or wherever you bought your SIM; probably won't help but it's worth a try.
Let us know if you figure it out.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Oridaem wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,833
