Replacement of broken plastic wing
I broke one of my plastic wings of my apple ac adapter. There are two small plastic pins to the left and right of the wing which are fixed it in a kind of hole at each sides of the outer plastic shell. One idea would be to reprint this plastic wing with a 3d printer, but I am not sure if there is a file which has this 3d information available and I also do not know if the material would be stable enough. Also I am not sure if this shell can be opened because I fear that the wing is not very easy to be replaced without opening the shell - the only way then would be to use pressure to position the reprinted wing.
Ist dies eine gute Frage?
I had the same issue - one side of the wing's "peg" had broken off.
So what I ended up doing was to find a small finishing nail that was the same size a the small peg sticking out. I then drilled a hole into the wing approx 3/8", then inserted it into the hole and cut off the nail so both the original and my new wing stuck out the same amount. (filed down the sharp edge of the nail from cutting too). Then very carefully began to push the wing back onto the power supply and --- presto! it works just like new.
von Matt Syracuse
