Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
574 Fragen Alle anzeigen
Display winking on and off?
Hi everyone.
I'm having a really annoying problem with my Macbook. This problem involves the LCD, that blinks if the lid is moved up or down.
To make it stop blinking I need to find a right angle of the lid or to press in the corners on the bottom right or left of the display.
Could it be the LVDS cable?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
Looks like the screen is broken... you might need to replace it. Not gonna be cheap though.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
In most cases when moving the screen causes image glitches like this it is due to a faulty LVDS cable. However, the non-digital looking yellow fade in the corners would indicate an LCD failure.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
The yellow faded corners are a mistake that I did using the heat gun to remove the front glass.
Thank you for the answer! :)
von
Antwort hinzufügen
robbitara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 110
