The extendable wand wont lock
the extendable wond wont lock in the extended position
Ist dies eine gute Frage?
There are two potential problems with this wand: #1. The rocker latch at the top end of the telescopic part: this is spring loaded, and the spring may have weakened or the metal 'tooth' in the bottom end may not be engaging because the plastic has warped.
More likely, though is #2: the white plastic rings at the bottom of each of the upper two segments have warped so that the three teeth on each are not holding firmly enough.
This is a problem, because they need to be removed and cautiously heated and bent back into the correct shape - and I don't know how to dismantle the wand.
If anyone does know, I will certainly try this fix and report back.
Ok - done, but this is easier to wreck than to fix.
First remove the bottom plastic end. This is held on by a tab that is just visible through the slot for the accessory lock. It won't push in until you have heated the plastic with a heat gun to soften it, but then you can use a flat-bladed screwdriver and twisting is better tban pulling, because you can push one side easier than the whe thing. Now you can slide off the white plastic locking rings, by levering up each of the 6 segments. The 3 wide tabs can be bent back in (just a little, if you hope to get the thing back together again) after heating with a heat gun until the edges begin to char(!)
Now reassemble. Maybe try some .003" shim to ease the tabs over the ends of the tubes. Remember that the slot in the bottom of the lowest tube sbould face the same direction as the release on the handle. Allow 2-3hours and a 30% chance of wrecking it.
War diese Antwort hilfreich?
Good answer, but proves sometimes its easier to just buy a new bit:-)
Sounds like a spring of some sort is missing.
Letzte 24 Stunden: 11
Letzte 7 Tage: 36
Letzte 30 Tage: 114
Insgesamt: 12,980
