Zum Hauptinhalt wechseln
The Sony Cyber-shot DSC-H7 is a 8.1-megapixel Super HAD CCD camera which captures enough detail for photo-quality 16 x 22-inch prints.
8 Fragen Alle anzeigen
My camera wont turn on
My camera suddenly stop working.Last night it was working.When I try to on the camera it is not getting on.So I thought camera need to be recharge. When I tried to recharge camera not getting recharge.
Please let me know the reason.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
this is happening to me too
von
Einen Kommentar hinzufügen
2 Antworten
Sounds like a blown fuse to me, if you don't want to pay to repair, try taking it apart locating the DC/DC pcb and checking the fuses. some times only a 50 cent fuse can cause this...
Good luck
War diese Antwort hilfreich?
Bewertung 0
I would check the battery to make sure it didn't die on you... If you never replaced the battery then it is probably very old and may have died on you... Batteries have a life span. CHeck the voltage first before you do anything. Next i would check the terminal connections inside the battery cage. This is an old camera and if you store the battery in the camera 24/7 the terminals can get pushed in and overtime will create a gap between the camera and battery terminals. With the door open push the battery inwards while attempting to turn the camera on. Do these steps first to eliminate possible battery or terminal issues and keep us posted.
Bewertung 0
Antwort hinzufügen
Subramaniam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 660
