Zum Hauptinhalt wechseln
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
If the vacuum is not turning on, what should I do?
I turned on the power button but the vacuum is still not starting.
Ist dies eine gute Frage?
Bewertung 9
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
If your Shark Navigator Lift-Away Pro refuses to turn on, use this Shark Navigator Lift-Away Pro Won’t Turn On problem page for possible causes and solutions.
First, make sure your vacuum is plugged in. If it is plugged in and the power button is on, you may need to reset your circuit breaker. If that option doesn't work, try resetting the motor thermostat. The steps to reset the motor thermostat can be found on the troubleshooting page.
If none of the above work, your cord may be broken.
War diese Antwort hilfreich?
Bewertung 2
Plugged in good circuit and plug no power still
Bewertung 1
My shark model # AH452 31 won't turn on.
Bewertung 1
The lights come on but the vacuum doesn’t work
Bewertung 1
The light will come on but it won’t start.
Bewertung 0
Antwort hinzufügen
Molina Oung wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 35
Letzte 30 Tage: 199
Insgesamt: 73,020
