Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
iPhone wont charge and keeps rebooting after replacing battery
HI, so yesterday i decided i would replace my battery that wasn't holding its charge very well. Low and behold i damaged the motherboard and the lock and home button both stopped working. I took the phone to a shop today and had the motherboard replace hoping this would fix my problem. Instead a new one has a arised, this being that every 5 minutes or so my phone reboots itself and doesnt charge even though it has the symbol saying that it is charging when plugged in. Whats my new problem? is it a short circuit within my phones wiring or is the new battery i installed worse than my old one?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I let the phone die completely, and now when plugged into the charger, the apple logo loads up the dies and the cycle continues
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This is the sign of a bad battery if I am correct. I saw a similar issue in an older thread here: iPhone keeps restarting after battery replacement.
Before the board replacement, did you attempt to turn on the device? Was this happening before?
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
had my battery replaced and all works well now however the front facing camera has now decided to stop working, oh the joys of phones
von
If you want the front facing camera to work, this guide here should show you how to check the connections for the camera to the board, just stop when you get to step 11.
von
Before diving in again, check if the proximity sensor and/or the ear speaker are working, if not then the cable needs reseating like Robert said. To check those, simply place a call to any toll free help-line. Can you hear the answering machine on the other side? When you place the phone to your ear, does it go dark? (or cover the ear speaker with your hand but the phone must NOT be in loudspeaker mode). If in doubt or afraid to break anything, have the technician who replaced the battery look at it, since this seems to have occurred after he changed your battery.
von
now thats crazy that happens when the logic board is bad but since they replaced it ?? try using the old battery with the new logic board if not then you got a bad board talk about bad luck
Bewertung 0
2 Kommentare:
i daren't open it again at risk that i might break it myself again!
von
yeah its scary but believe me messing up is the way to learn I have fixed about 100 phones now and sometimes i get in trouble still thats why I dont do repairs for cheap :)
von
Antwort hinzufügen
ToddRichardson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 3,446
