Zum Hauptinhalt wechseln
This is a 2006 HP model number NC6120 laptop. Enclosed within a black case, it contains a 1.73 GHz Intel Pentium Processor, 512MB of DDR RAM, and a 60 GB hardrive.
2 Fragen Alle anzeigen
Frage geschlossen
How can I stop my computer from running extremely hot?
Whenever I boot up my laptop within 5 minutes it starts to become very hot, how can I fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
A very simple and easy fix to this problem is to take out the fan, and clean the fan with compressed air. Alternatively, you can replace the fan altogether. For more help on this,check the HP Compaq NC6120 Troubleshooting Guide for repair help!
War diese Antwort hilfreich?
Bewertung 1
1. Turn off the computer and disconnect from power source(s)
2. Use a vacuum cleaner to suck the dust out of the fan from both outside and inside vents
3. Use the brush mouth piece for the vacuum cleaner to clean the inside of the computer case if you can open it (don't do this if you don't feel comfortable with it)
If step 2 does not work send the computer for repair. However, I have done this for years to all my various computers and I have never had any other computer problems whatsoever.
Good luck and all the best
Peter
Bewertung 0
1 Kommentar:
And yes I forgot I have a Compaq laptop too that overheats in the summer. I solved this problem by buying one of those fans you sit the computer on and plug it in to the USB port for power. Works a treat :)
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 184
