Zum Hauptinhalt wechseln
Das Asus Zenbook UX31A ist ein Laptop, der im Juni 2012 veröffentlicht wurde. Es ist ein Mitglied der Ultrabook-Reihe von Asus. Es verfügt über einen Intel Core I7 Prozessor der dritten Generation und ein Full-HD-IPS-Display.
How to fix power button?
My problem is that I can't turn my Asus on.
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
2 Antworten
It is most probably this problem :
Nicht reagierende Tastatur reparieren
See also :
Asus Zenbook UX31A: Nicht funktionierende Tastatur reparieren
Asus Zenbook UX31A Bild
Anleitung
Schwierigkeitsgrad:
Leicht
10 minutes
Anleitung
Schwierigkeitsgrad:
Leicht
15 minutes
War diese Antwort hilfreich?
Bewertung 0
If you may have slipped any liquid on the keyboard, it may become not responsive. As the only option to power up the laptop is via pressing the 'power' button on the internal keyboard, you won't be able to turn on the laptop.
Removing and cleaning the keyboard may help but not necessarily -- this laptop's keyboard is a thin thing and you can't really clean 'in-between' its layers.
You may want to replace the keyboard as the first option.
Or if you reasonably suspect that the liquid could have gotten further down from the keyboard unit, you may want to 'ring-out' your motherboard first.
As to me, I've firstly checked that the motherboard was OK, then replaced the keyboard. Everything started to work as a chime.
If your keyboard works but the touchpad doesn't - check that the touchpad wire is firmly connected (from memory, to the back of the keyboard rather than to the motherboard -- but I can't remember for sure). Sometimes the connection gets lose (and may especially get lose while you are working on replacing the keyboard).
Bewertung 0
Antwort hinzufügen
Dai Quy Phan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 10,562
