What screen assembly works for the Straight Talk model?
Model number is sm-s975L. What lcd digitizer assembly with frame will fit this phone?
Ist dies eine gute Frage?
If you are going to be using a display assembly that is not already adhered to a midframe, then it does not matter as these display assemblies (when off the frame) are not carrier specific. You can get any display assembly and install it without issues.
War diese Antwort hilfreich?
Does that mean that any s4 display assembly will work then??? Can you clarify?
Yes, any display assembly will work if it is *OFF THE FRAME*. Take heed, those last words are important. I must go now, for there are other worlds than these.
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 1,081
Anyone? I feel someone out there has to know this.
von Austin Harris
I search the Internet and ended up here. I assume it is the same at the att model, but dont know. Can anyone confirm
von kevin
any answer to which model is compatible with the sm-s975L?
von jlopel
Same as any GSM model
von lisadunn121766
