Zum Hauptinhalt wechseln
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
22 Fragen Alle anzeigen
no electric to horn, lights, and starter
tried to start scooter after a long winter, but nothing. tried charging the battery, and still nothing. replaced the battery and still nothing. no lights, no horn and no attempt to start even with a new battery,
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
sandycav, check the wiring on the battery connectors, make sure they are nice and clean. Your scooter has a main fuse in the power line. Check that one for continuity and make sure that you have power going to the fuse. If all that is okay, use the attached diagram to check for power. You will of course need a multimeter for that.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks! I've visually checked the fuse yesterday and it looked ok. I'll get a multimeter and try to check from the battery out.
von
Antwort hinzufügen
sandycav wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 41
Insgesamt: 6,086
