Zum Hauptinhalt wechseln
Das Nexus 6 ist ein Android Smartphone, das Google in Zusammenarbeit mit Motorola entwickelt und 2014 herausgebracht hat. Es verfügt über ein 6" Display.
Can I fix my cracked screen myself?
I have a Nexus 6. I dropped it. Shattered my screen. Where would I find the instructions and what tools to use?
Ist dies eine gute Frage?
Bewertung 14
1 Kommentar
It is very difficult to change just the broken glass, but you can get it done here for a good deal: http://www.ebay.com/itm/Nexus-6-Motorola...
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
It seems like this instruction is for the entire display. Is there any way to replace just the glass?
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
von
Please see the following guide on replacing the display assembly for the Nexus 6: Nexus 6 Display Einheit austauschen.
Bewertung 0
https://www.youtube.com/watch?v=iNSUOpRU... Here is glass repair only.
Bewertung 0
I wouldn't advise replacing the glass yourself. It appears to be a complex process as the glass is glued to the LCD display. If the LCD isn't cracked, it is worth a try. The alternative is to replace the LCD digitizer entirely. Currently the LCD digitizer cost approx 180 USD and fairly easy to install, providing you follow the guides and have the right tools. I would advise you to replace the LCD digitizer, buy a glass screen protector (the replacement digitizers from China are not Corning Glass) and a new case to better protect your phone.
Bewertung 0
Antwort hinzufügen
Tammy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 9,406
