Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Why is my mac very slow at operating and fan very loud!
My MacBook Pro 13" unibody late 2011 core i5
Runs very slow at booting and even when the laptop is fully on everything is basically slow,the mouse drags alot and sometimes I get the spinning color wheel but all the time the mouse moves very slowly even when track pad speed is set to max.speed and the harddrive has nothing on it to slow it down because the harddrive is empty.and the fan makes on !&&* of a noise that even when I installed smcfancontrol the fan still makes noise and the laptop isn't over heating.
The moment I power on the laptop the fan starts making noise.ive tried lots of stuffs like performing fresh osx installation even when I perform installation it runs slowly I've changed the harddrive severally and I've double checked the ram.and the ram is 8gb all seems not to work.but when I use boot camp on windows it runs normally and fan control slows down the speed that I was forced to be using my mbp like other windows laptop.the moment I install mac the slowness and fan noise kicks off again please what do I do
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try starting up in Safe Mode by holding down the Shift key on start up and let us know your results. A history of the machine might help us here.
UPDATE 11/28/15
I have two identical machines in from different sources right now with loud fans and complaints of overheating. Any help would be welcome but it's probably an Apple defect and no one has filed a class action suit yet. There are 14 complaint about this on the Apple discussion site and no solution.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I'm from the Philippines and I have this problem too. I am planning to upgrade the RAM and change HDD to SSD (maybe include a data doubler by replacing the CD/DVD Drive) but it seems I have to delay my plan after reading this. Too bad I already ordered my SSD for it.
Safe Mode booted faster than normal but the fan is loud. The pointer movement and dock animation are jittery and some dialogue boxes flickers but not the whole display. I find it odd. I've been scouring the internet for some answers.
von
Antwort hinzufügen
PrinceAde wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 4,793
