Zum Hauptinhalt wechseln
Model A1347 mit 2.4 GHz oder 2.66 GHz Intel Core 2 Duo CPU
Using DDR3 PC3-10600 rather than DDR3 PC3-8500
Hi all,
Has anyone tried putting in the larger DDR3 PC3-10600 ram into the mac mini mid 2010 rather than the recommended DDR3 PC3-8500.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Here's a good reference: DDR3 SDRAM
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sure the faster (newer) modules will work. But you don't gain anything as the systems memory access speed is fixed.
I would just buy the cheaper modules. Also remember the systems limit is 16 GB.
Before you do anything make sure your firmware is upto date. Follow this Apple T/N: EFI and SMC firmware updates for Intel-based Macs.
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
I have run into some machines where the faster RAM DDR3 PC3-10600 would not work in a DDR3 PC3-8500 native machine. I know it should but it didn't. This was last seen in a 2010 15" MBP.
Bewertung 4
3 Kommentare:
Thanks Mayer, I'll consider this before I buy.
I wonder if Apple have a software hack to stop it...
von
Same here, put 10600s into MM 2010, three beeps only. Will not run.
von
@chrishees - Check the PCH logic as the older series won't support the newer SO-DIMM's.
von
Antwort hinzufügen
Nim Anderson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 10,992
