Zum Hauptinhalt wechseln
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
78 Fragen Alle anzeigen
Parking light and a/c system
parking light not working and a/c system not working. fuse is normal. what is the problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Make sure that you have enough battery in the car cause sometimes if you dont have enough battery in the car it might disable features to save battery.
and bring it to a repair shop and tell them to look behind the ac and by the lights for faulty wires
hope this helps
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
and also make sure that you have a new bulb in the light
von
ac doesnt blow cold air. The fan works and when the a/c control panel switch is pressed, the light turns on but a/c does not engage and no cold air
Bewertung 0
Antwort hinzufügen
Philip wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 531
