Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 4 ist ein Smartphone, das im Oktober 2014 heraus kam. Die Modellnummer des Galaxy Note 4 ist bei der amerikanischen Variante eine der folgenden: SM-N910, SM-N910A, SM-N910T, SM-N910V, oder SM-N910R4.
Frage geschlossen
How to remove retail mode?
Hey all:
I have a few Sprint note 4's. I can't figure out how to get them out of retail mode. I've tried using Odin to flash stock firmware and it doesn't remove the retail software. I've tried holding volume up when rebooting and it says, "MDM settings don't allow factory reset." I've gotten AT&T Note 4's out of retail mode with no issues, but these Sprint phones are stubborn. If anyone has any experience with this, or any suggestions, I would love some advice.
-Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 19
13 Kommentare
اعاني نفس المشكلة في موبايل not4
von
Hey how did you get the at&t ones out of retail mode permanently?
von
I bought a Galaxy Tab A from Meier. It is stuck in retail mode. I've tried all the passwords listed, but nothing works. I get invalid password.
von
Well I'm meeting with a representative from the store Friday who is supposed to help me remove retail mode. Hopefully it will work and if it does, I will share how we got it done.
von
Don't work on Verizon Samsung Galaxy Note 4
von
8 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
28 Antworten
Gewählte Lösung
From Canada here,
you go to the app called Retail Mode. First password is the - 5444, then you will click off disable retail mode. will ask you again for password. that you will use the M729Q16K8546. It will then as you if you want to factory reset phone. Click yes.
Just did this on the Samsung Galaxy S6 Floor model phone that was given to me from a friend to make it usable.
will update if it's all said and done!
War diese Antwort hilfreich?
Bewertung 26
17 Kommentare:
after you put in both passwords, just click home button. go to settings privacy and lock screen I think. You need to go to device manager, and unclick the retail mode. retail mode will then be off after you do above comment. just going to attempt to flash it with a new firmware.
von
Wanna know if there is a way u could use the cellular on the rEtal unit. Once you successfully remove it??
von
Please Please Please help me out..
i'm stuck with the samsung retail mode, want to be always updated with apps from this site and accidentally tried installing this apk on my main phone (Airtel/India) GALAXY S6.
Unable to uninstall this mode..!!
von
This is very helpful information
I tried the above details on my galaxy Note 4 and it was reset
very grateful
but I dont no if there is a way i can use cellular with it
von
Thanks. Had issue on my son's Samsung Galaxy Tab E 9.6, as all installed aplication disapeared after some time and lots of settings wasn't setting, like screen brihgtness and anoing screensaver when in sleep mode. I noticed strange task in tasks list. It was in retailer mode for some uknown reason. Box with tablet was sealed and didn't noticed any damages of seal. Anyway all sorted after entered paswords above and factory reset. Thanks for info.
von
12 weitere Kommentare anzeigen
If your demo tablet originated from BestBuy, the administrative password is "blue" without quotes. See, i.e., http://kollins.com/wp-content/uploa...st.... I can confirm that this password worked on a Galaxy Tab S 8.4 running KitKat.
Yesterday at 7:27 PM
Bewertung 7
10 Kommentare:
Also worked on a Samsung Galaxy Tab E from Verizon! Thank you!!!
von
Yes it worked, thank you.
von
Thanks a lot!! :D
von
Nope...I also have a Galaxy tab E and blue didn't work. As well...none of the passwords have
von
Used the blue...but nonow its asking for another code. Do you remeber?
von
5 weitere Kommentare anzeigen
I also had few AT&T note 4 on retail mode but this passcodes was able to disable it and i am using it with t-mobile now. Passcode: 5444 and M729Q16K8546. This codes only work for AT&T.
I have a sprint note 4 but can't still disable the retail mode. Anyone with an idea on how to disable it?
Bewertung 6
8 Kommentare:
So I'm guessing everyone has already tried flashing the samsung firmware via odin and samsung kies?
These are the usual instructions, but I think you've already tried.
-Go to the app drawer and open an app called Samsung Retail.
-Go to Configuration Settings and enter the password 5444 to unlock it.
-Uncheck “Disable the factory reset” and enter the following password M729Q16K8546.
I'm guessing putting custom ROM would be another solution too.
von
hello, i just succeded in doing so.
i first used odin to upgrade the firmware to the 5.01 stock international firmware. then, always with odin i rooted it.
finally i installed titanum backup from the market, which allowed me to remove all the apps i wanted from the device.
von
anyone who will guide me about removing retail mode on note 2 ..
i had enter a password 5444 but service enable option would not working.. anyone have any solution for it
von
First password 5444, worked for both apps (samsung retail mode & galaxy retail mode)
Second password
M729Q16K8546
von
Works great here in Canada too, just talked a friend through it on the phone and it's resetting as we speak.
von
3 weitere Kommentare anzeigen
There are many passwords out there that are worth a shot.. some stores use their own passwords. (And in some cases the phone allows you to pick from a list of retailers, so pick Walmart and try these 2) Here are some I know of:
Walmart device: rollback, Walton
Bestbuy: blue
Others I’ve read have worked (worth a shot right?!)
- galaxy
- ruletheair
- rethink
- demomode exit
- instoredemo
- unlimited
- remove cod
- nationwider
Bewertung 6
8 Kommentare:
Can anyone help me with a galaxy tab A 10.1? I got it for my daughter and it's stuck in retail/demo mode... It was from Target and they said to get ahold of Samsung which got me nowhere.. I've tried the "5444" "unlimited" and everything else on this thread so far with no luck... My daughter needs it for school and this is a huge Inconvenience, any help would be much appreciated!!!
von
any luck fixing your tab a ?
von
@tryintohelp thank you so friggen much for that list of pass codes!!! I just spent the last hour looking for the right code and found it on your list!!!
von
TryinToHelp!, thanks you!!!
von
Thanks bro <3
von
I believe you have to go into the Retail mode app and disable it, the password is unlimited I believe.
Bewertung 4
5 Kommentare:
I tried the password unlimited but it invalid to disable the retail mode. Appreciate your help though.
von
Whoever wants a fresh restart, I'll do it for £50. Just inbox me and I'll make sure it's all new.
von
Hey you still offering your service
von
@retailmodeguru r u still servicing the needy of r.mode?
von
@retailmodeguru can you help me with the retail password for a samsung s23 ultra from atnt
von
if t-mobile try magenta
Bewertung 3
5 Kommentare:
it worked for me on t-mobile note 5. thank you so much buddy!
von
No problem my friend.
von
thanks worked on t-mobile for galaxy s20+ 5g
von
Thanks for great help . Works like a charm
von
I don't know why I didn't think of that... spent 2 days trying to remove retail mode... lol
von
Have you tried to completely delete everything off the device in recovery?? I would delete everything you can then reflash the rom. Hopefully that helps. If not let me know.
Bewertung 1
1 Kommentar:
Nothing changed. As soon as I reflash the ROM it goes straight back into retail mode.
von
Try 5444 or galaxy, worked for a tablet that had retail mode on it.
Bewertung 1
retail mode pasword remove cod
Bewertung 1
Bought a samsung 6 edge plus off Craigslist. Of course it's in retail mode! I already tried the 5444 password, but no luck. It's asking for the store password. I have no idea where it came from. I tried "rollback" for Wal-Mart muy that didn't work...i tried "blue" for best buy...that didn't work. Any other thoughts? I don't really know how to root. Is there more passwords I should try? Ugh what a ripoff
Bewertung 1
3 Kommentare:
Walton was another one
von
I used that code "rollback" to unlock the s9+ from retail mode
von
Rollback worked on my Galaxy Tab A-8GB.
von
Can’t do that, because phone debug is on and due to retail mode can’t turn it off.
Bewertung 1
4 Kommentare:
von
How do you do it. I have a demo z fold
von
@retailmodeguru how do I inbox you I'm new to this site
von
@Rasel, how do I inbox you?
von
I tried the password unlimited on the note5 and it worked. after that I turned off the factory data reset "which is the first option" and it automatically removed the retail demo mode.
Bewertung 0
2 Kommentare:
I also have the note 4 demo unit. Been having trouble with the retail software resetting my phone every now and then. I lost some very important photos. Is there a way to change the software at least so that it runs the same one as the actual note 4. Will I be able to use my sim card after that?
von
That's for Sprint only.
von
Meu galaxy A3 ta no retail mode o que faco?
Bewertung 0
2 Kommentare:
You can learn english so we can help you
von
Pual Somlea can suck a dick.
von
hello, i just succeded in doing so with a device n910x. (no imei)
1. i used odin to upgrade the device to the stock international firmware 5.01
2. always using odin i rooted it.
3. finally i installed titanium backup to remove all the apps i wanted from the device.
Bewertung 0
Managed to use the password above to remove the app and flash with odin, but the retail media files - pics and videos still on there and when I click delete it says failed to delete. Any ideas if anyone removed these? It's about 2.5gb of files
Bewertung 0
1 Kommentar:
Wipe data/factory reset should do the trick in recovery. Instead of using volume down to boot use volume up instead.
von
Try
Flash twrp or cwm recovery in Odin wipe data flash SuperSU.zip and reboot
Bewertung 0
I have a Samsung Galaxy S2 tablet with retail mode on it. I've tried 5444 and all the other passwords listed above none of them work. It is from Barnes and Noble so it starts up as a nook does that matter? I've tried to master reboot and delete but still won't work. Can anyone help
Bewertung 0
1 Kommentar:
Download simple factory reset apk
von
Its very simple you allow the factory reset mode and tgen you flash twrp, deleta all data,and lastly install sw with odin. Its very simple if you need anything just ask!
Bewertung 0
If it’s a Walmart one. The password was either Walton or rollback. I called a sprint store and asked if they could get in touch with a rep for Samsung & hour later got a text of the password. Gotta be smarter than a fifth grader.
Bewertung 0
1 Kommentar:
Ok do what did the text say... Why tell us this and not share the password given to you from samsung
von
hi i have a cricket galaxy sol 2 retail mode how do i remove it
Bewertung 0
2 Kommentare:
its a cricket galaxy sol 2
von
download apk factory reset on the phone
von
Help, I did hard reset many times and did the Factory Reset many times and it didn't delete the Live Demo Unit.
Bewertung 0
I had. A samsung. S9 plus from fido and the password that worked was 5444 for both passwords
Bewertung 0
Bewertung 0
probastes simple factory reset
apk que teléfono es y que compania?
Bewertung 0
1 Kommentar:
I have a Galaxy Tab A I purchased from an auction and it is in Samsung Retail Mode. I do not know where it originated from, is there a way to determine that so I can figure out password. Also, using passwords above should I capitalize them all or no. Please help this is a Christmas gift for my grandchild. Thanks
von
I have galaxy watch 3 I cant get live demo mode
Bewertung 0
1 Kommentar:
Try rollback
von
(rollback) is the password for samsung retail mode if 5444 does not work try the passcode above
Bewertung 0
2 Kommentare:
I need a atnt note 20 retail mode password
von
I hace tried all the ones you have listed no luck
von
can you please help me with an LG V60 Think Q retail mode removal, please !!!
Bewertung 0
Need help with a galaxy a51 stuck in retail it’s from Costco but no password I’ve tried works so far
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 38
Insgesamt: 209,988
