Water damage on Fitbit Charge HR
Have a Fitbit charge HR. Jumped in pool with Fitbit on.. Jumped out...
No sign of life:(
Any suggestions??
Have tried drying in rice, recharging and holding button ...
No change..
Anything else I can do?
Ist dies eine gute Frage?
6 Kommentare
I went into the pool also with my Fitbit and it is reacting the same way!!!!! This is a great question that many people ask.
von Genesis
If you end up getting a replacement from fitbit I would be happy to buy your old one.
von Seth McMichael
shoot... happened to me as well.. is there any answer regarding this issue?
von adamaidilpadali
Hi @adamaidilpadli.
You could try using the ifixit battery replacement guide to open the watch, disconnect the battery and then clean away as much of the water as possible using Isopropyl Alcohol 90%+ and a soft toothbrush. Be gentle when doing this. When finished allow it to fully dry. Shouldn't take long to dry as is alcohol. Then re-assemble and don't forget to reconnect the battery. Good luck with the repair.
Take pictures before disconnecting /removing anything as an aid to re-assembly in case you forget which way it was etc.
Fitbit Charge HR Akku austauschen
von jayeff
Same problem here. Second Fitbit this has happened to.
von Laurie Lewis
1 weiteren Kommentar anzeigen
