Zum Hauptinhalt wechseln
Das Sony Xperia Z3 ist ein Android Smartphone, welches 2014 auf den Markt kam und bekannt ist für seine lange Akkulaufzeit und Haltbarkeit.
114 Fragen Alle anzeigen
How to glue properly a lcd?
Hey, i am having the same issue all the time. When i glue a lcd or glass on the frame it doesnt hold enough and then it is like that:
http://shrani.si/f/3p/J6/1ylWj2pW/img572...
What should i do? What tape should i use?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
Your best bet is to actually purchase the pre cut adhesive, not only is this extremely strong, as you can usually get the original stuff that's used to hold it down, it is also quite easy to fit without mistakes.
I first tried doing it with my own double sided adhesive at first, but wasn't getting it to sit as flushly as I wanted, I then started buying the pre cut adhesives for the Xperias, and my repairs went way smoother! As an added plus, although not guaranteed, it will be more water resistant than trying to use your own adhesive. :-)
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Have you tried applying a little bit of heat around the screen? Sometimes this will help to make the tape stickier. Just add pressure and slowly work your way around the screen applying heat as you go.
Bewertung 1
Antwort hinzufügen
infoservis112 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 236
