Zum Hauptinhalt wechseln
Repair guides and support for a wide range of Vespa scooters.
starting issue, battery good, makes noise but no start, ideas? Randy
206 vespa, 900 miles, no start and battery tested good, just makes a noise but no start< Randy
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare:
You'll need to provide a lot more information, there are many things that can prevent it from starting. What model of Vespa? You are saying the starter is not turning the motor over? or the motor is turning but not firing? Is the noise a clicking or a whirring noise?
von
rappinrandy , what noise does it make? What have you checked?
von
RE: 2001 Vespa 150 CC
My Vespa has been on a battery tender almost a year and I have started it up with no problem. This morning, it would not turn over. Has gas though it is old. Has oil but again, it’s old.
Any suggestions / remedies?
Thank you,
von
Einen Kommentar hinzufügen
2 Antworten
hi
1st check your fuel system if it feeds correctly and make sure the carburators are clean
2nd check your high tension wires if it does fire up your spark plugs
hope it helps
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
i bet the noise your hearing is from the starter when it try to start the engine.
von
Starter Bering's locks or neutral safety switch is bad
Bewertung 0
Antwort hinzufügen
rappinrandy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 619
