Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Frage geschlossen
iPhone 5s drains quickly even without using it
Why is my iphone 5s drains quickly even after replacement? Can anyone help me for this? It doesnt last overnight even without using it. I turn off the 3g and close all the apps. But it doesnt work for me.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I take it you replaced the battery? Did you get it from iFixit or somewhere else? There are a lot of poor quality batteries around but it's worth paying the extra for an iFixit one.
War diese Antwort hilfreich?
Bewertung 1
If replacing the battery from a reputed seller like iFixit doesn't fix this, you could have a board issue.
Most common board issue is the U2 / USB IC being defective. This makes the phone burn through the battery very quickly, and other symptoms such as the iPhone is not detected by iTunes and/or when the battery is completely drained, it will not recharge back although the symbol on the screen will say "charging."
Other causes: poor reception causing high power consumption; OR during previous repair(s) some parts where omitted, causing the phone to have poor reception and again drain more power; OR short in some parts of the board, using up the power (must be overheating); etc.
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 153
