Zum Hauptinhalt wechseln
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 Fragen Alle anzeigen
Frage geschlossen
XT 910 Broken display and short circuit
Really that happen with my XT910. I explain to you, I was updating of Android 2,3,6 to 4,4, everything was all right, but when the reboot did, the phone was been frozen in the logo of start screen by more 1 hour. I tried to remove the battery, in this action, I touched for 1 second or less, the screw positive with the chassis. At the moment turn off. Next I finished removed the battery, but maybe for the pressure that I did, the display on the inside suffered 2 cracked when I went back to mount the battery and I tried to turn on it, only the phone heated up . After the event, I do not know if has only broken diplay, if I must give charge to the phone, if the phone have any protection, if the motherboard or the battery have put on short circuit. Thank you very much beforehand.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Esteban, "only the phone heated up ." heat=short circuit. A bad display will not cause it to heat up. It is possible that you have a bad battery, but more likely you shorted a component on the logic board. You can try and see if you find a component that looks charred or is missing. Sometimes you just have to let it get hot and actually destroy the part that shortens out. It's a bit of a hit and miss situation.
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 168
