Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Broken LCD, constantly vibrating. Need to find LCD replacement
Last night, I tried replacing my 2 year old Iphone 5's battery. During the process, instead of lifting up the frame, it instead lifted up the screen itself. Me not knowing during that time, removed the glue only to realize it was wrong. I then proceeded to lift up the frame and got to the part where the battery was on. After replacing the battery, I put all of it back together turned it on,but noticed that the screen loose. This lead me to open it again and try to fix whatever was broken. I never found out the reason why, but after putting it back together it then proceeded to "lose display" with a waterfall effect showing different lines of color then proceeding to become black with the backlight still on.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You can buy it from ifixit
iPhone 5 LCD and Digitizer
Or another vendor. Here's a guide, as to how to fix it
iPhone 5 Display tauschen
iPhone 5 LCD and Digitizer Bild
Produkt
$39.99
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Purchase a new screen assembly from iFixit or another reputable supplier.
Bewertung 1
2 Kommentare:
Are there any other reputable suppliers? I dont need the whole kit and am in a tight budget right now
von
Dunno if we're supposed to say this, on this site. Without getting spammed. Basically try eBay. Try for one that says oem. Even though it's probably not. Try for the country you live in, so returns are a little bit more probable, if something were to go wrong
von
Antwort hinzufügen
Jean Nathan Prado wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 81
