charging paused, temperature battery too low
my samsung galaxy s4 gt i9500 won't charging, i check batt temperature is -25C , i already replace usb cable flex but still not work ,
sorry for my bad english
Ist dies eine gute Frage?
hendri, since you " check batt temperature is -25C" then it is definitely to cold. Double check the -25C.;-) The usual causes for this error are issues with the battery connector, failed btemp line on the circuit board, bad battery, bad charging port flex. So if I would fix it I'd start with a new charger, then a new battery, then do some fault finding on your logic board.
War diese Antwort hilfreich?
hendri ,
just clean the battery terminals
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,306
1 Kommentar
take out the battery and keep the phone under direct sun light for few minutes and try charging again
von salikasumanapala
