Zum Hauptinhalt wechseln
Visual Land Prestige Elite 7Q is a 7" Tablet with a quad-core processor, 8GB of memory, and comes with Android 4.4 (KitKat).
screen broke from the inside can I fix it
My tablet got crack from the inside can it be fixed. Some one please help
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
does the tablet still work?
Power on can you see the screen and does it respond to touch
von
It turns on but all u can see is liqud. No it does not respond to touch
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
patty abarca, from what you are describing it sounds like a broken LCD but intact digitizer. It will help if you post some images of what you see with your question. Use this guide to do so. The LCD's are readily available at places like this and many others. There are no repair guides out, so I would suggest that you check check on here as well as on here for similarities. When you do decide to work on it, [URL|make] create a guide so we can all learn from it.
iFixit Bild
Anleitung
Bilder zu einer vorhandenen Frage hinzufügen
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
Visual Land Prestige Pro 7D Display Bild
Anleitung
Visual Land Prestige Pro 7D LCD Display Replacement
Schwierigkeitsgrad:
Schwierig
30 - 40 minutes
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
patty abarca wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 461
