Zum Hauptinhalt wechseln
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 Fragen Alle anzeigen
My washer stops at the rinse cycle
Washer fills, agitates no problem. then the washer will not spin rinse
or anything else the washer is done. this is the same on all 3 different cycles.
There is no hum like it wants to go or any sound at all.
Timer? Motor?
Update (10/13/2015)
model 110.20922990. I don't believe it is a clogged drain. Because after you get the
timer past the wash cycle on any of the different wash cycles, there is nothing.
Not a buzz not a hum nothing. You can move the dial any place after the end of
the wash cycle and try to start the washer with no luck. You can go to the spin
cycle and try to start the machine no go. You can go back to the wash cycle nand
start it up no problem.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
5 Kommentare
My whilpool washer won't cut off the water it does good on the other cycle
von
Do you think it could be the washer lid. Switch
von
Sorry Barbie, I really dont think the lid switch is your problem.
von
My Kenmore washer series 100 he will watch but when I get on the rinse cycle it won't it'll stop my light we'll start blinking will not do anything else help me please
von
I have the same issue as Elida Greene, on my Kenmore Gas Laundry Center (Model 2671532).
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer may stop mid-cycle. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Cause 2
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch prevents the washer from operating. If the door lock is defective, the washer may stop mid cycle. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s diagram and use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Thanks!!! I realized the bleach dispenser (which I never use) was turned sideways and the lid wasn't closing.
von
thank you on the lid switch . . . how bout the timer
Bewertung 0
1 Kommentar:
@chichchick - Do you have exactly the same problem? Do you need to ask your own question oristhejustgoingtbearunonquestion which are hard to understand?
von
My kenmore washer washes and when it gets to rinse / spin it dont throw water the machine stop like its done it makes a little sound like it wants to spin or something but then it stops and stay on rinse/ spin all hours it don't move
Bewertung 0
Antwort hinzufügen
bogart wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 38
Letzte 30 Tage: 164
Insgesamt: 29,877
