Zum Hauptinhalt wechseln
Die GoPro Hero3+ Silver Edition (Modell-Nr. CHDHN-302) wurde im Oktober 2013 veröffentlicht. Dieser digitale Camcorder kann Videos in 1080p-HD-Auflösung aufnehmen und Fotos mit 8 MP machen.
My video is being split into two different files
When I film a clip longer than 10-11 minutes, the go pro will create multiple files instead of continuing to record to the same file. Is this normal/can it be changed?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
When filming longer segments with any GoPro including the GoPro Hero3+ Silver Edition, it will disperse these extended videos into chunked up videos. No frames are lost in this process, but you will have to put them together in whatever video editor you are using so that your video will once again be a continuous stream. This is a completely normal thing when filming with a GoPro.
Upon inserting a SD Card into the GoPro, it will use a storage system mainly called FAT32 and for bigger SD Cards FATex. These file systems are good because they are very compatible with all kinds of computers (keyword VERY). This entails that these file storage systems can only process files of a maximum size around 4 GB. Now a days this may not sound like much, but back in the 90's when FAT32 was invented that was more than anyone would ever need. Being so, when filming long segments with any GoPro it will break up your video at different time segments depending on what resolution you are filming in and/or what rate of frames you are shooting per second. The higher quality equals more space. So knowing this just make sure your memory card has enough space for the entire time you want to film and you should be just fine!
Good luck and film on!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
There is more on this GoPro Hero 3+ Silver Edition issue at it's own Troubleshooting Page: GoPro Hero3+ Silver Edition Troubleshooting
von Teilen
Antwort hinzufügen
Patrick Cook wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 5,504
