Zum Hauptinhalt wechseln
Die erste Generation des Bose SoundLink Mini wurde am 1. Juli 2013 veröffentlicht. Das Gerät wiegt ca. 0,7kg und hat eine Bluetoothreichweite von ca. 9 Metern.
20 Fragen Alle anzeigen
The SoundLink Mini isn't playing music!
The speakers show that my device is connected, but I can't hear my music.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
1. Check your devise's bluetooth setting and make sure it is paired to the speaker.
2. Check to make sure the volume is turned up on the speaker.
3. Check to make sure the volume on your device is turned up.
4. Turn off the bluetooth on other surrounding devices that may be paired, or perviously paired with your speaker.
You can also find more troubleshooting tips for this issue on the follow problem pages:
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
My Bose Soundlink doesn't make any sound. Normally it make sound when I turn it on or pair it with bluetooth. Now nothing and it pair with my phone but no music.
von
my Bose Soundlink works very well, and sounds really great. But it doesnt last than 3 seconds. After I play a song, in 3 seconds I hear a noise and then the sounds gone. But, the sound comes out when I type. If you have any idea, please, tell me. Thanks!
Regards.
Bewertung 0
2 Kommentare:
We have the same problem. Mine works well too but it doesn't last 3 seconds. Were you able to fix it?
von
Change the battery
von
Antwort hinzufügen
Chris Martinez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 5,804
