Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
261 Fragen Alle anzeigen
MacBook Pro suddenly shutdown , date and time reset to Jan 1.
Hi. My MacBook Pro (MD212) sometimes shutdown (not "gracefully") with no warning given. The date and time reset to Jan. 1 midnight. This happens when the notebook is on battery power. To be specific, it's more likely to happen when the remain battery is between 30%-60%. I have never experienced this issue when plugged in. And the sudden shutdown happens under both Yosemite and El Capitan.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hey Starry,
You might have a bad battery. The time and date resets whenever there is completely no power source detected. This indicates that there is a complete disconnect between the battery and the board. Hence why it only happens when you are on battery power. It might be showing as 30%-60% but that can be hit or miss with a bad battery.
Best of Luck!
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thank you for your insightful analysis. I ordered a new battery and have mine replaced today. Unfortunately the problem persists. I think I have to have a look at the logic board.
von
Update: Much thanks! I reset the SMC and the new battery works with no problem. The shutdown issue no longer appears.
von
Antwort hinzufügen
Starry Chiu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 63
Insgesamt: 11,826
