The screen on my device is bad.
Half of my screen is not showing up what should i do?
Ist dies eine gute Frage?
Hi Tim!
This could be caused by either a loose display connector or a faulty display module. If you follow the Screen Repair Guide through to the fourth step, you will be able to re-seat the screen connectors by carefully unplugging them and plugging them back in, making sure that both ribbon cables are fully inserted into their connectors, then reassemble the device.
If this doesn't fix the device, you probably have a faulty display. The same guide linked above will show you how to remove the display module entirely, so that you can replace it with a new one.
Happy Fixing!
Josh Kinney
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 81
