Zum Hauptinhalt wechseln
Die Neuauflage des Apple 13" MacBook Air von April 2014 wurde mit Dual-Core i5 und i7 Prozessoren aufgefrischt. Die Akkulaufzeit wurde etwas verbessert.
313 Fragen Alle anzeigen
Frage geschlossen
Used SSD safety Concerns
My hard drive is broken and I need to buy a new one. When buying a used hard drive, is there any risk involved? For example, could my device be taken over by a virus or would I be liable for someone else's old data, for example?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
First, you are not liable for someone else's data why would you be? Thats assuming you bought the SSD from a reputable supplier.
As for viruses on the replacement SSD, I would recommend you create a bootable USB thumb drive with a virus checker installed with the latest definitions file if you are concerned. That way you can clean it off if you find one.
War diese Antwort hilfreich?
Bewertung 3
First your machine does not have a hard drive. it uses a SSD stick.
MacBook Air 13" Early 2014 Solid-State Drive (SSD) austauschen
Do what Dan said with the stick, but I'd wipe the drive with a reformat.
I really like to use the "write zeros" option in Disk Utilities when recycling any hard drive. If it fails I know the drive is no good. If it passes, either all the blocks are good or any bad blocks have been maped out in the directory.
Bewertung 2
1 Kommentar:
@Mayer - I don't think you ned to go that far, Formatting: Yes. Writing: Ones & Zeros No. Unlike disk drives SSD's don't get bad blocks, they get bad cells from writing to the same location. The onboard CPU on the SSD does a CRC check of each cells write to make sure the cell is good if not it grabs a spare cell to write the data. Basically, do the least about of alteration to the SSD to gain the most life.
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 85
