Zum Hauptinhalt wechseln
An Android 4.4 smartphone released in August 2014.
108 Fragen Alle anzeigen
charger port not charging
charger port is broken
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
thank you for acknowledging my question
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Rebecca,
If you are asking about the actual wall charger then simply use an appropriate USB cable (fits the phone at one end and the computer at the other) and plug one end into the phone and the other end into a known working USB port on a computer that is operating, when you have to charge the phone until you get a replacement charger.
Here is a link to a supplier of chargers for your phone. As you can see they are not expensive. I dare say that it is cheaper to replace it than to buy the parts to fix it.
Using this method to charge the phone takes longer than when using a charger as the port doesn't supply as much current as a charger. You can make it charge a bit faster by ensuring that the phone is switched off whilst it is being charged.
War diese Antwort hilfreich?
Bewertung 1
Charger piece broken can't charge my phone upBLU 5.0 phone
Bewertung 0
1 Kommentar:
Please tell me how fix my 5.0 blu phone charger
von
Antwort hinzufügen
natalieinnis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 960
