Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
265 Fragen Alle anzeigen
Frage geschlossen
MacBook very slow without reason
I have a macbook that is verry slow without a reason. The harddisk is replaced with a 120gb kingston SSD. The RAM is replaced with new Macbook compatible memory. And the operating system is reinstalled.
So the os is as clean as it can be. CPU 98% inactive, memory 1,33 of the 4gb in use, harddisk 20gb in use of the 120 gb. Upgraded to the newest OS.
When i click on a button i have to wait for 10 seconds. The installation have cost almost 12hours. So something makes the Macbook unusable slow. Can someone help to fix this Macbook.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You're not going to like what I'm about to say.....
You have two most likely scenarios here.
First, run an AHT. (Boot the device holding the "D" key to get to the menu. Some devices on the borderline need opt + D if holding just "D" doesn't work)
If all checks out there... you'll need to wipe and reinstall the OS. It should not take your machine near anything close to 12 hours for an OS install. I just installed a fresh copy of Lion, then Mountain Lion...then Mavericks (before I realized my machine rated for El Capitan)... then El Capitan... on a 2008 15" MBP core duo with 4GB of RAM... and the whole process (because of my goof) took my machine 4 hours.
First of all, make sure that all of your hardware you replaces is rated for your machine. i.e. the SDD, make sure that the RAM clock speed is rated for your machine, etc.
Given that it took so long...and you're getting incredibly slow response times... I would say that either your RAM or SDD is faulty.
Run the AHT. If you get bad results, then you know 100% what to do. If no errors are found... then you'll have to do a fresh install.... then go from there.
I'm sorry. I wish that I had a cooler answer for you.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hard drive cable?
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 115
