Zum Hauptinhalt wechseln
Repair information for the Gaggia Classic Espresso Machine.
20 Fragen Alle anzeigen
water is not coming out….
hello, water is not coming out when i press the botton to make an espresso.
I think it has to do with the fact that the coffee had been coming ver very very slowly because the grind was too fine…. (tight)
help
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
If no water is dispensing even with the portafilter removed then the solenoid valve that feeds the brew head may have clogged. The water passage in it is very small and easily plugged by calcium flakes or other debris; you'll need to take the top off of the machine and remove the valve to clean it. Descaling and/or backflushing usually will not help.
War diese Antwort hilfreich?
Bewertung 4
I had exactly the same problem. It was a really easy fix. Follow the instructions for cleaning the "shower screen" by removing it with a screwdriver as shown in picture 3 at the Gaggia sire at http://www.gaggia-usa.com/machines/semis...
You can get the user manual telling you about this on page 14 at http://www.gaggia-usa.com/support_docs/G...
Bewertung 1
2 Kommentare:
I have to clean my solenoid valve monthly. I finally bought a new one and clean clogged valve with CLR so it is ready to change out. You can find YT video from Whole Latte Love website with step by step instructions.
von
Use citric acid. CLR is a bit overkill. If you have Cafiza, you could use that, also. Works best if the water is very hot. Soak for 3-5 minutes, brush out, go. Cheers, -- j.
von
Follow this You Tube link - Unblocking a Solenoid Valve on Gaggia Espresso Machines ...
Works a treat every time.
Bewertung 0
Antwort hinzufügen
palixc wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 64
Insgesamt: 28,825
