Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
20 Fragen Alle anzeigen
Replacing 27" Cinema Display LCD with iMac LCD
I'm trying to replace my 27" Cinema Display's LCD but I'm unsure about compatible panels.
I need LM270WQ1(SD)(B1) but do other panels work too? Like the ones for the 27" iMac?
Btw, it's not the Thunderbolt-version.
Thanks!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It will work with the iMac display, but you’ll have to transfer the display board and backlight of the old display. I did it and it works great.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
Hi there' I'm interested to know more on how you did this, I have all the relevant parts etc, and have enough skill to try, please could you possibly elaborate more on what you actual did to get it to work, I kindly await reply.
von
but I think I know what you mean.
von
I am interested in this solution... I have good known display boards, but did not understand the backlight part of the answer. Do you mean the LCD function cable, or the actual led strip? Can you elaborate?
from what I can tell, the cable that goes to the led strip has the same connector in the two displays...
von
Antwort hinzufügen
MacF wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 1,910
