Zum Hauptinhalt wechseln
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
51 Fragen Alle anzeigen
I forgot the unlock code to switch on the phone...
My screen got damaged and had the phone given to a friend's shop to have it repaired.But due to lack of availability of the part,it had laid unrepaired for quite sometime.In the meanwhile i bought a new phone and i gorgot the old code to even switch on the phone that i has been repaired and delivered today.plz help!!
Ist dies eine gute Frage?
Bewertung 14
11 Kommentare
gabrielkige@fikas.no
von
confused with the way I should answer your question
von
nokia n8 security code remove
von
plaese help me
von
I have my Nokia N8 working now after I had lost its charger. After trying to charge it by using my samsung S5, it worked but can not use it now because I have completely forgotten the code. Can you help me to recover my code.
von
6 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
john punkbuster, you could try a hard reset. "Hard reset
This will delete everything on your phone memory. Backup your data if you can. Make sure your phone battery is fully charged before performing hard reset
1. While the phone is off, press & hold below 3 keys simultaneously,
For SYMBIAN^3 phones (Nokia N8, C7, E7, C6-01, X7, E6): Volume Down Key + Camera Key + Menu Key
2. Ensuring that above keys are being pressed, Press & hold Power button until you see “Formatting” on your screen
3. Release all keys & wait for formatting to be completed
4. Once completed, Phone is like just out of the box
5. Most importantly, your security code is now reset to the
default 12345 - from here
War diese Antwort hilfreich?
Bewertung 5
3 Kommentare:
i will reset phone but 12345 code eror
von
Hi, when my nokia n8 is off i try to do the hard reset for formatting cause i have forgotten my security code ( Volume down + Camera + Menu key then while holding those three keys i hold down the power button but nothing happens. Phone starts up gives 2 x vibration then goes off. Please help
von
Hi, can someone please assist. I haven't resolved the issue.
von
To unlock your mobile there have many solutions. You can unlock mobile by manually or pc. Here I have given so many solutions.
Bewertung 2
Antwort hinzufügen
john punkbuster wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 89
Insgesamt: 23,200
