@lebane I'd definitely use a multimeter and check for continuity. If the fuse is truly blown, replace it with a proper one. Since your image comes from the service manual, I assume that you have that. Then you know that the fuse is Sony part number 1265-7224 which is a .25A 1X0.5mm fuse. There is a reason it is fused and the last thing you want to do, is cause a bigger short circuit. If you must apply a jumper to test it, just solder a piece of wire across the top of the fuse. You can buy the fuse at places like this as well as on here
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
6
Have you tested the fuse to confirm it's blown?
von Brendan
Nah, it was working before after i replace the screen it stopped working. I think the fuse is gone.
von LeBane
How will you know unless you test it ? You think soldering a wire across is easier than using test leads on multimeter ? lol
von John
